Possible to create a "vertical" section in revit
sagnewYUXLR
sagnewYUXLR
hi i was wondering what's the quickest way to generate a plan view of small localised zone?
is this even possible?
i am modelling an industrial plant from a point cloud just now and with so many pipes etc being able to almost cut a vertical section in a section view would be great, rather than having to continually mess around with view ranges.
is this possible? many thanks
ralphdenhaan
Just create a Section in a section and then rotate it 90 degrees:
(If I understand you correctly)
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
sagnewYUXLR
superb cheers
