Error: "Cannot delete output file"
I do not see a technical support or installation board, so since I am an architect I will ask here
I am trying to install Revit LT 2024.0.2 Update and US English Content v1 for Revit LT from the Autodesk site. I have Revit 2023 on the computer which was updated from 2022 last fall. Last night I downloaded and successfully installed Revit LT 2023.1.2 Update. When I try to install the 2024 and English content files it extracts the update but then I get the error Extraction Failed little window with
This happens with both files. I tried running the updates as an administrator and got the same error. I searched the forums and found someone else had this error with a Fusion update and the problem in that case was MacAfee anti-virus. I deleted MacAfee (it is a relatively new computer that came with MacAfee and I use different anti-virus programs) but that did not help. Any thoughts?
