hi i was wondering what's the quickest way to generate a plan view of small localised zone?
is this even possible?
i am modelling an industrial plant from a point cloud just now and with so many pipes etc being able to almost cut a vertical section in a section view would be great, rather than having to continually mess around with view ranges.
is this possible? many thanks
Gelöst! Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
Just create a Section in a section and then rotate it 90 degrees:
(If I understand you correctly)
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
