I've had this problem with certain doors and/or windows that cut through a wall that has horizontal reveals. If the window or door touches the edge of a reveal, it (sometimes) spits out one or both of the following errors and causes the door or window to be deleted.
"Can't cut instance of window/door out of wall"
"Could not create integral wall sweep for wall instance. Failed to cut wall."
At face value, I understand these are common user-errors and I could be doing something wrong. But the odd part is this: if the wall is in one orientation, it seems fine, but if it is rotated or mirrored say 90 degrees or 180 degrees, Revit can no longer calculate the void intersections for some reason and it deletes the objects. See attached screen capture and model.
Is this a bug, or is Revit supposed to act like this?
Is there a better way to get window/door openings to cut through reveals cleanly?
已解决! 转到解答。
