Pop-up and drop-down menu bugs
studioWU6AE
Message 1 of 9
studioWU6AE
Ultra wide monitor with a 2024 Revit seems still to not work, considering dropdown and right click popup menus.
Edit. The bug is: the menus don't show, they are not visible. Right click menu does not appeaer, and dropdown menus don't appear.
I was investigating the issue using Google and mostly discovered similar issues, earliest dating back to 2005. Is it really so that this sort of glitch just keeps on tagging along - is it not an industry standard yet, to make sure at least these things work, whenever there is a publishing of a new version? 2024 has been out for a year, and the pop up menus don't work. There's soon gonna be a 2025 version - hopefully at least the pop up menus have been fixed before that.
I am posting this under a small frustration as this was NOT included in the list of "things I need to test with 2024 before I move to it from my 2023 Revit" -things. I did general testing, doing stuff, making sure regular things work, then I proceeded to switch, which is always a multi hour project - and as I started to do actual design with the 2024, I only discovered I am utterly unable to do any real design with the product due to such a small and tiny bug. Just one button on my mouse, and it does not work and stands between me and the product.
I did find some mentions that this has been reported as a bug which is a nice thing, I guess. If any community member has similar issues and has actually discovered something that helps, I'd be happy to hear.
Things I've tested:
-Rebooting
-Windows resolution scale is 100%
-Running the software in compatibility mode for a slightly older Windows (sometimes this helps for random things..)
Currently what I am doing:
-Installing a 2023 version
Thank you for reading this or replying to this. Sorry in advance, if this is a common issue and I have not given any new input to it. Cheers.
Replies (8)
Message 2 of 9
Alfredo_Medina
I have not seen issues with popup windows nor drop down menus in Revit 2024. Do you use 2 monitors? Sometimes the display scale of the monitors is different, causing this kind of issues. I use only 1 wide monitor, so I have not seen that problem. But I had the issue (with a previous version of Revit) at the office, using 2 monitors, and that was the reason for the problem.
Message 3 of 9
What specifically are these "bugs" doing? You didn't mention. Only that you are "utterly unable to do any real design with the product" because of these "Pop-up and drop-down menu bugs".
Message 4 of 9
studioWU6AE
Sorry, I forgot to specify that. I added the explanation to the post.
Message 5 of 9
studioWU6AE
Interesting. Perhaps there is someting wrong with my Windows, then.
I am using only one monitor.
I'll do now some research considering these issues in general in Windows, instead of just Revit.
Message 6 of 9
Have you contacted your Autodesk reseller about this?  I would.
Message 7 of 9
What OS are you using?  11?
Message 8 of 9
studioWU6AE
Yes, Windows 11.
Message 9 of 9
@studioWU6AE wrote:
Yes, Windows 11.
Interesting. I have been waiting for more Win 11 feedback on this forum, but there's not been a whole lot of it.
Autodesk just declared last year that Win 11 is FULLY compatible with 2023 and above.  I was and remain incredulous about that claim.
Windows 11 compatibility and support for Autodesk products
