point cloud link not visible after saving project.
GabeGarcia
Message 1 of 21
GabeGarcia
i'm having trouble viewing a point cloud in a rivet project after saving and reopening the project.
so i started a new project and inserted a .rcp point cloud that we received from the building owner. i was able to bring it in, view and aligned with no problems. then i started to trace and insert fabrication parts. everything work and operated normal. so i save the project and close the app. then when i go to reopen the project the point cloud is not visible.  so i go to manage links and the point cloud is still loaded with the correct path to its location. so i hit the reload button and nothing. so i use the reload from button select the same file location and apply with no luck. then i remove the point cloud then add the point cloud from the same path and then we get the point cloud to be visible.
the strange thing is in the same project i inserted the same point cloud and then inserted a different point cloud from a scan that we did for a different project. then i save and reopen and only our in house point cloud is visible.
anyone else having these issues?
Replies (20)
Message 21 of 21
bennetjac0b
Saved my life 7 years later!!!
