Point Cloud convert to Revit Model
BIMAbhi
Advisor Advisor
BIMAbhi
Can you please suggest us what are the software platform by which we can convert our point cloud scan data to Revit model.
We know the below application name for this conversion. Please share other application names apart from below mentioned list.
  1. EdgeWise [ClearEdge]
  2. Leica CloudWorx
  3. San to BIM
Thanks in advance.
Thanks & Regards
BIMAbhi
BIMAbhi
Please help me to find out the good tool for converting the 3D scan data to Revit model.
Thanks & Regards
BIMAbhi
here are the steps that I can suggest:
  1. check the input data. It should be consistent and without errors
  2. prepare for modeling (register scans, post-processing). You can do this ether in the "scanner software" or in Recap.
  3. import data to Revit
  4. start modeling
  5. check the results
Here at BIM Machine we do a lot of modeling for our clients. If you won't be able to solve this issue on your own, you can drop me a line to nb@bim-machine.com
BIMAbhi
Thanks fro your feedback.
Thanks & Regards
BIMAbhi
Converting point clouds to actual Revit models is a challenge and, from my experience, cannot be fully automated.
We use Faro As Built solution to help in managing and modeling from point clouds in Revit.
https://www.faro.com/products/construction-bim-cim/faro-as-built/as-built-for-revit/
How much does it cost?
