I am placing plumbing accessories into my revit project. I drew the toilet paper holder and towel ring myself but when I load them into my project they do not show in my certain floor plan views. My visibility graphics are set to show plumbing fixtures and they are not hidden. So I can't figure out why they wouldn't be showing up.
Solved by syman2000. Go to Solution.
Is your plumbing accessories hosted to floor instead of level?
No, it is hosted to the level.
Actually I am not sure. I drew it in a general plumbing family file.
Can you check the view range and see if the cut is below those objects.
