Hi
I have a constant plotting problem where 1 of the office PC plots directly from revit 2017 to plotter with no problems.
There are another 3 PC all loaded with Revit 2017 which do not plot at all, the only work arround that somtimes works is to create a PDF and then plot from a PDF reader. The Pc that does work plots directly to the plotters IP Address. Have checked the setting and all the plotter seetings are identical.
This problem has been driving me nuts since updating to 2016, always an intermittent on the three PC.
The Plotter is a HP Designjet 4520 HPGL2.
Have tried removed and reinstalling Revit 2017 no change.
Removed and reinstalled Plotter and updated drivers, no change.
Have created a network plotter on the office server, no change.
Have updated the 3 pc to windows 10 from windows 7 64 bit, no change.
When large sized PDF's are created from the other machines in the office, only the 1 PC is able to plot them.
Any other suggestions I can try?
Regards
Graham
Hi
Regards
Graham
So just a bit more information
Autodesk was adamant that the problem with plotting at my office related to the display cards installed.
So to check we bought a new Display card installed it in one of the office machines that does not plot.
AND GUESS WHAT !!!!!!!!!!!!
Revit 2017 still does not plot
WHAT NOW
TIRED OF THIS PROBLEM AND CONTINUED SILENCE FROM AUTODESK
WHAT NOW
STILL SILENCE FROM AUTODESK
HAVE HAD PHONE CALLS FROM SINGAPORE BUT ONCE PROBLEM IS EXPLAINED AND MAILS SENT NO FEEDBACK
ORSOLYA PLEASE FORWARD THIS TO YOUR CODING DEPARTMERNT TO RESOLVE .
PLEASE NOTE WE HAVE 5 X AUTODESK BUILDING DESIGN SUITE PREMIUM 2017
1 X AUTODESK AUTOCAD 2017
1 X ARCHITECTURE ENGINEERING CONSTRUCTION COLLECTION
ONLY ONE MACHINE IN THE OFFICE CAN PLOT TO THE PLOTTER.
SO THE WHOLE OFFICE HAS TO CREATE PDF'S AND PLOT FROM ONE MACHINE
THIS IS PATHETIC WAKE UP!!!!!!!!!!!
I'd suggest dropping a machine back down to Windows 7 and testing to see if printing works fine.
Another reason most companies are still running Windows 7 vs 10... Revit 2017 is working just fine on my computer at work...and I can print to the copier or plotters.
BTW....if you want to rant and rave about this....tag the support folk that replied previously so they get an e-mail you replied. If they still work for Autodesk they may return.
Also...do you have a support ticket with Autodesk? I'd keep making comments on the support ticket on progress on your issue.
Oh, do you have print monitoring software? Try disabling that and see if it works, That was a headache at a company I worked for...it worked for Autocad but Revit didn't like it....and trying a different one it worked vice versa.
Yeah, we are using DC too... I like printing to PDF so I can rearrange General sheets that Revit prints last (Since A is before G) and when printing multiple sets, moving sheets around is a PITA...
So Updated to Revit 2018 and guess what still not plotting.
What is happening
Autodesk sent out a tech to load Revit 2015 on one of the office computers.
And guess what Revit 2015 can plot directly to my plotter with no problem.
So what has Autodesk changed to cause 2016 2017 and now 2018 to no longer plot directly to the plotter. The whole office has to create PDF to plot.
Tired of talking with no answers and Autodesk not making any progress
My office has 7 Autodesk packages
(5 x Design Suite Premium
1 x AutoCAD
1x AEC collection ) with subscription fully paid up.
This is not good enough.
What is happening
1 x AutoCAD
this is so what i did not want to hear. i have paid for 2 upgrades, yet still use 2016 because it is the only one that plots. i was hoping 2018 would solve the plotting problem. it sounds like autodesk continues to sell a product that doesn't work. This would not be tolerated in most industries, yet here we continue to pay subscription fees for a product that doesn't work. The sad part is they know we have to use them, and we know we have to use them, regardless of whether it works or not. this is really disheartening to hear that 2018 still doesn't plot. what can we do?
