Hi, I've been struggling to find a way to show my walls on the second floor of my model. I can see columns walls and everything in both 1st
and 3rd floors. I have tried using plan view and change the cut region but nothing has worked. The walls go all the way up from bottom to roof in 3d
view, and even though some start at the bottom and some start from the second floor, They are visible in first and third floor but not the second.
I have also gone into visibility/graphics and checked if everything is on. And the settings aren't different from each other in each floor plan. I have also tried creating a structural plan and even there it isn't visible.
I have a hand in in 4 hours , if anyone is fast enough would be much appreciated.
Otherwise it is still good to know.
Thanks in advance for any advice
Mike
Solved by loboarch. Go to Solution.
If you attach the Revit file it would help others help you more efficiently and more promptly to resolve your problem
Thanks not sure what you mean by phase or template. I'm attaching the file
It is the phase and phase filter settings of the view. If you match the settings for those values to the Level 1 Floor plan view the walls show up.
@michalcapek4 wrote:Thanks not sure what you mean by phase or template. I'm attaching the file
Sincere appologies; I didn't imagine that you wouldn't know about Phases; otherwise, I would have attached an image or screencast 🙂
Loboarch did the necessary
