Plan Region
6 REPLIES 6
3274 Views, 6 Replies
Plan Region
Hi all, I've been working in the model below and am trying to use a plan region to cut through the high windows except when I cover all windows I want to view it make some of the wall invisible. I've tried multiple plan regions changing settings in the view range ect. Does anyone have a good solution to this problem as it has happened to other projects too.
Cheers, Kurt
Tags (1)
6 REPLIES 6
Are you trying to change the cut representation of the window? If you are, please be aware that the cut representation of a Window comes from the Family not the Project.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
in reply to: barthbradley
Hi Bradley,
As the windows are higher than my cut plane of 1200mm i'm using the plan region to through at 2200mm so I can see the windows. Not sure if that is what you wanted to know.
bin
Can you screenshot the view range sheeting of the view, the plan region, and an elevation or 3D view of your model?
indiana_j0nes
You mean to say the plan region is not showing the walls at some instances?
Like seen in the first image?
Would it be possible to share the file to investigate?
XXalessio.amodioXX
Imagine you have a moltitude of windows how many plan regions do you have to use?
I would suggest insted to modify the family itself.
You can create a 2D symbol for plan view and Hide in plane the "Solid" part of the window.
Let me know.
Hi All,
I've worked out a solution but not why it happens. I had 3 windows side by side to make one window. As soon as I separated the windows by 1mm the walls reappeared.
Thanks for all your advice
Forma Design Contest
Technology Administrators
