Plan region not working
526996629
526996629
I have some low windows on a certain level in my project. I changed the cut plan in the view range of that plan to 100mm. Meanwhile, I need to show the stairs to be the same as other levels. So I draw a plan region at the stairs and changed the cut plan to 1200mm. However it's not changing anything. It's showing the same as without the plan region. Any suggestions?
rxi.gg
can you upload the model to check it please?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
I noticed it's because the plan region didn't cover the whole stair which lead to my problem. No neeed for other solutions, thx.
Basma.Abdelhalim
It happened with me, and it also needs plan region to be drawn as unrotated rectangle.
