PLAN DOESN'T SHOW UP IN THE PUBLISHED VERSION
smikhaeil
Message 1 of 10
smikhaeil
We have an ongoing problem; that some of the enlarged floor plans don't appear properly in the published version on BIM 360 Team, the problem doesn't exist if we print the sheet as a pdf file. The sheet looks okay on the screen too
Please see the attached screenshot and your input is highly appreciated
By the way, below are things that we have checked and everything seam to be normal :
- Phase and Phase Filter ----> Show Previous + New, Project Completion
- View's Crop region ---> See attached
- View's Model Display = normal
Replies (9)
Message 2 of 10
Have you checked your Publish Settings.
Message 3 of 10
smikhaeil
Thank you for your reply,
I've just checked the Publishing settings, and all plans in the sheet preview look fine and nothing missing, a screen shot is attached; I've tried to republish multiple times and the problem is still exist
any other ideas?
Message 4 of 10
Kelsey.S
Autodesk Support
Autodesk Support
Hi @smikhaeil,
I am not clear on what is missing or different when you publish on Docs versus PDF locally.
Do others get the same results?
Thanks.
Kelsey Skaug
Autodesk Technical Support
Message 5 of 10
Kelsey.S
Autodesk Support
Autodesk Support
Hi @smikhaeil,
Just checking back to see if the issue is still occurring or if there are anymore details you can provide.
Thank you.
Kelsey Skaug
Message 6 of 10
What did you check specifically regarding View Crop region?
Message 7 of 10
smikhaeil
Thanks for your reply,
Yes this issue is still exist and it is very annoying to our clients, vendors and consultants who use the online published version as the only source to get into the latest and greatest construction drawings.
Here is a screencast to the whole issue, and I hope someone can help us
Link to screencast  https://www.screencast.com/t/4VwIs24kY9p
Message 8 of 10
smikhaeil
Hi, thanks for your reply,
Here is a screencast to the whole issue, please let me know if you still need any further information
Message 9 of 10
Reset the View crop region of that view and see what brings you.
Message 10 of 10
smikhaeil
It worked, when I reset the View crop region to default; thank you so much!
Case is closed, you are the best!
SM
