Getting rid of Annotation in consultant`s families
3 ANTWORTEN 3
Nachricht 1 von 4
388 Aufrufe, 3 Antworten
There is a Revit family practice that annoys me a lot: when people put text or annotations in their 3D families, especially in non-cuttable families.
To them, it`s an easy way to have a scalable symbol associated with their families. I often see this in electrical plugs, cameras and washing machine appliances.
The bad result is that if your plan in looking through a floor, you see these symbols pop up. What mostly happens is that people will close the engineer`s model altogether, making the model less collaborative. Alternatively, they will modify all their view templates to hide these items in the model. Both solution are not-ideal as they involve more work and result in less coordination.
I do not care about the symbol aspect of the annotation. Meaning, I don`t care if their symbols scale or not. Is there not a proper way to model families without these negative effect? It seems that using drawing lines works, they don`t appear through floors. Alternatively, would it be possible to create an annotation symble that is external to the family but updates with it? Like it would rotate when a camera rotates?
Has anyone dealt with this problem and found a suitable solution? Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
@Anonymous wrote:
Has anyone dealt with this problem?
All the time.  Thank God for Hide by Category, Hide by Element and Hide by Filter.
Nachricht 3 von 4
Export their models to IFCs and link the IFCs in your instead.
Nachricht 4 von 4
als Antwort auf: ToanDN
Hi Toan,
That`s actually quite a good solution for some projects. Thank you. In our case, it won`t work because we are in BIM 360 Design and I believe that would require an export quite often.
I have a few leads as to potential solutions:
-Making the equivalent annotation not scalable as model lines in the model
-Making an external annotation that represent the 3d aspect accurately in cases where there is a direction, like a camera
-Making the family cuttable
I feel like there are potential I`ve overlooked some potential solutions, like yours. Thanks for your contribution and let me know of anything else comes to mind :leicht_lächelndes_Gesicht:
