Placing Face Based Lighting into Linked Revit Ceiling
Message 1 of 24
I am having issues placing a face based light family into a revit linked ceiling. I was able to do it just fine on 1 floor - then am not able to on the proceeding floor. the Floor I was able to do it on (SC1) has a view range as Follows:
Top: Level above (Cellar)
Cut Plane: offset 6'6"
View Depth Level: Level above (Cellar) 0' offset
the level i cannot place the fixtures has the same settings but 1 floor up and for some reason I cannot place the face-based fixtures. Any help is appreciated!
Replies (23)
Message 2 of 24
can you place it in a 3D view?
Message 3 of 24
are you seeing this on the contextual tab? And are you selecting Place on Face?
Message 4 of 24
Yes - i am selecting "place on face". I will check to see if i can place in a 3d View
could it be something to do with my underlay settings? as i am using autocad to underlay the lighting postions. On the floor I was able to do it no problem, My underlay settings were Base Sub-Cellar 1; Top: Cellar; Orientation: look up.
on the floor there is the issue the settings are the same but wont let me place the fixtures in the Look up setting, only look down. But when I place in the look down setting, it doesnt place on the drop ceiling.
Message 5 of 24
Instead of guessing, just post your file and we'll figure it out in no time.
Message 6 of 24
Make sure the view is Hidden, not Wireframe. And try to TAB on a linked ceiling see if there is actually a ceiling.
Message 7 of 24
see below link for the files - elec is the base and the other is the linked revit
i was able to place on SC1 but not in the Cellar ceiling
thank you!
https://rxelectric-my.sharepoint.com/:f:/p/cmesker/EsshvXL2KvROtCqkF0H0YKwB3KqvebjcbSEWDUxeEEzxsw?e=...
Message 8 of 24
so the wireframe change helped me to place on face - but when i export to Navisworks- it looks like they are hosting to the floor above slab and not the drop ceiling
Message 9 of 24
Cut a section and see where the drop ceiling is then make sure your view range cut plane is not above it.
Message 10 of 24
arch ceiling in the linked model is at 9'6 1/4" +/- depending on the room. below are my view range settings.
Message 11 of 24
What is the dim from CELLAR to 1ST FLOOR?
Message 12 of 24
and my underlay settings - as it appears this affects whether or not i can place
Message 13 of 24
Are you able to place the light in 3D?
Message 14 of 24
cellar is at -13'10" and 1st Fl TOS is -1"
Message 15 of 24
unsure of how I would place a lighting in a linked arch model. how would I see a 3d View of just the cellar Ceiling?
Message 16 of 24
3D Section Box.
Message 17 of 24
i can place this way but it is difficult to get to the right ceiling height and see the linked cads to act as a background.
I am just confused as to why everything worked perfectly on SC1 but not on the cellar?
thanks for all the help !
Message 18 of 24
After you place it on the ceiling in 3D, go to the Ceiling Plan View and adjust its position.
If you go to the Ceiling Plan View and don't see it it the View, then the problem lies elsewhere.  Maybe View Range, maybe Visibility Settings, maybe something else.  Placing it in 3D is more a troublshooting step.  You should be able to place it in the Ceiling Plan View.
Message 19 of 24
when i placed in 3d, i was able to see in the ceiling view. I can place when my underlay settings are look down, but it doesnt attach to the ceiling and upsidedown, why would it not let me place with my underlay settings looking up like i did for SC1?
Message 20 of 24
Huh? You've completely lost me.  Can you post a picture or something to help me visualize what you just described?
