Placing color in details in section view
Im using revit 2017 and am trying to add color to some detail items in my section views. Can anyone explain to me how this is done?
Ex: i used detail lines to draw in a 2" rigid insulation on the inside face of my buildings concrete foundation and want to color the interior of that area pink
Use a Filled Region -- Solid Fill, Colored.
When i do filled region I'm only seeing the option of having an opaque or transparent background with a hatch pattern
You have to create a Filled Region TYPE, similar to the OOTB "Filled Region - Solid Black". In fact, just duplicate that one and change the color. Easy breezy.
How do you create a filled region type?
What would keystrokes be if you know them off the top of your head?
Would that be done from the annotate tab?
You create a Filled Region Type the same way you create any type.  Easiest approach, like I suggested, is to duplicate an existing Type and edit its type properties.  You can find existing Types listed under Detail Items in the Project Browser.
Thank you for your time and responses
