Can't make extrusion in place family
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
4144 Aufrufe, 4 Antworten
Good afternoon,
I am working on a project that will not allow me to make an in place family all of the sudden. It was working fine and suddenly it allows me to open the editor and draw the profile, but no matter the profile I draw, even as simple as a rectangle, i get an error when clicking the green check mark stating "can't make extrusion". Any ideas of why this would happen?
4 ANTWORTEN 4
Nachricht 2 von 5
cbcarch
als Antwort auf: Anonymous
Check the current workplane--make sure it is set to a surface that you are trying to extrude on.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 5
als Antwort auf: cbcarch
Work plane is set to surface and I'e even tried to set to ground plane. Still the same error. I can make sweeps, blends, and all other shapes, but not a simple extrusion.
Nachricht 4 von 5
You sure you gave it a depth/height? Perhaps start and end of extrusion are zeroed out.
Nachricht 5 von 5
als Antwort auf: barthbradley
Awesome!! That fixed it. I was thinking it was something complex. It ended up something that simple. Thank you for your help!!
