Placing Ceiling based objects in plan view
Hi
 I have a smoke detector family which is ceiling hosted, i would like to be able to place these in a 2D ceiling plan view but when i try nothing seems to happen. Is there a trick to this or something im missing?
Attached is the ceiling hosted family
constantin.stroescu
try this:
  • in Family Editor > Family Category and Parameters > Family Parameters > check :Work Plane Base - OK - load into the Project
  • in Project : Ceiling Plan > Placement > Place on Face and click on Ceiling - place the object..
Constantin Stroescu
Hey Constantin,
 I have tried that to no avail, when placing revit does recognise the ceilings but when i actually click to place it, nothing happens.
constantin.stroescu
I'made the steps in Revit 2016 and Revit 2017 and I don't see any problem...As an observation the 2d symbol that comes with the family for 2d Ceiling Plan seems to be much larger then usual and comparated with the 3d modeled object ( that is not visible in plan view)
Constantin Stroescu
Check "Work Plane-Based" in the Family and set the type parameter for default elevation to 0'-0".  Then reload it and place on a work plane.
