Problem with Stair Constuction
Hello Sir,
I hope you are doing well, i have problem with stair case whenever i make it using component method, it creates an extra riser at the top, Please check my attached Revit file and highlight the exact solution to avoid such issues.
Thanks and Regards
Bilal Ashraf
Melina.Vlachousi
You need to edit the stair run instance properties:
Dear Sir
I couldn't find this option in Construction, I have attached a Screen shot
Thanks and Regards
Melina.Vlachousi
1. Find the stair you built in your model and select it.
2. Click on "Edit Stairs"
3. When you are in Stair Edit mode, select the stair component.
4. Look in the properties window. It is the one that is usually visible on your screen, not the window that appears when you click on edit type:
Dear Madam, Thank you so much for the Help, I really appreciate that
Regards 🙂
