Placing camera to look directly up?
J_Lewis87
J_Lewis87
Does anyone have a good way to place the camera so it's looking directly up vs forward?
L.Maas
Place camera in section. After that you can move the whole camera in a floor plan.
Cameras do not snap, therefore it is always approximate.
Otherwise you could try to use Dynamo to create a script that places (and rotates) the camera.
Then you might get accurate results
Louis
Please mention Revit version, especially when uploading Revit files.
martijn_pater
Maybe in 3d view you could switch to bottom view and set this view as perspective view, if not with camera.
hmunsell
  • place the camera in Plan view
    • open the camera view
    • open a section
    • tile views (should have 3 views open).
  • select the Camera view crop region and change to the section view
  • you should see the Cone and Depth and Target Elevation grip
  • select the elevation grip in section and drag it up.....
Howard Munsell
syman2000
Cut a section and add camera. Place where you want the camera to be and then point up the ceiling
Result is you get funky angles
J_Lewis87
Thanks, all. Your instructions worked.
J_Lewis87
The only problem is when I render my stair tower, the planes parallel with the floor are blurry. Any ideas why?
