Place a family in specific coordinates
9 REPLIES 9
Message 1 of 10
mairh_tsek
3048 Views, 9 Replies
Hello all,
Do you know any way to place a family in specific coordinates(X,Y,Z) in a project using Revit ?
Thank you in advance!
9 REPLIES 9
Message 2 of 10
in reply to: mairh_tsek
You can't.  But with Dynamo this is fairly straight forward.
Message 3 of 10
you can do it either :
  • by using Revit:
    • from VGO >Model Categories > Site , check the Project Base Point
    • once activated in your drawing Unclip it so to be able to move it freely
    • change the N/S (Y) and E/W (X) and Elevation (Z) of the PBP icon so to move it to the desired coordinates
    • load the Family that you want to place and use Align tool to match the PBP position
    • now , if you want it, you can move back the PBP to the original position and Clip it ...
  • by using Dynamo
Constantin Stroescu
Message 4 of 10
Or I guess you could also add dimensions with global parameter labels for x-y coordinates on some level to some zero point. Or you could even build offset coördinates into your family.
Message 5 of 10
mairh_tsek
in reply to: martijn_pater
This is what I am trying to do, to create inside the family the X and Y distance from the 0.0 point of the family. But when I place the family in the project the 0.0 of the family not correspond to the PBP  of the project.
Thank you.
Message 6 of 10
martijn_pater
You should be able to just align/lock a family to any point/refplane/grid...
Message 7 of 10
mairh_tsek
I make the calculation in Revit (Coordinates family - Coordinates project). After I import the family in the project and manually I put the cross (0.0) from the family to the PBP.
Sometimes I have negative values in the calculation results. Is there any way the direction of the coordinates in the family to change directly?
Message 8 of 10
martijn_pater
You could use a nested work-plane based generic model family with some model lines (for coordination purposes, with visibility parameter) and use the offset constraint both for positive/negative values, or controlled by the main families parameters.
Message 9 of 10
..and another way , this time , by using Dynamo:
https://knowledge.autodesk.com/community/screencast/631d1e59-6c6a-4f8a-b151-34334e149b47
Constantin Stroescu
Message 10 of 10
I am trying to do it. How is it possible to add also the degree factor? The PBP has an angle and also the families have an azimuth.
Thank you.
