Pitch roof cut-out
Pitch roof cut-out
Leticia_Campanelli
Message 1 of 9
Pitch roof cut-out
Leticia_Campanelli
Hi there,
I am new in Revit, using LT version.
Can anybody let me know how to cu out the pitch roof under the flat roof connection properly?
Kind regards
Replies (8)
Message 2 of 9
fred2193
Did you model this as two separate roofs?
Message 3 of 9
fred2193
sorry that was a dumb question from my part 😉
Message 4 of 9
fred2193
Can you maybe post a copy of your roof model in a project file? I can try and find a solution for you
Message 5 of 9
Leticia_Campanelli
Hi Fred,
I am clearly a beginner in revit.
I copied to another file and it looks different. Maybe there is another way of coping it.
it is attached below.
thanks
Message 6 of 9
fred2193
Thank you, I'll will reply to you as soon as I have a solution to your problem 🙂 You are welcome to send me a copy of the original file, if the roof looking different in the copied version is a problem
Message 7 of 9
Leticia_Campanelli
It should be fine. Thank you!!
Message 8 of 9
It this what you are after?
Message 9 of 9
Leticia_Campanelli
Hi there,
Yes, The flat roof should be higher, but in any case how did you cut out the edges (internal under side)  of the pitch roof and flat roofs to a certain level?
thanks very much
