Pipes not showing in section views
Joe_Hughes
Joe_Hughes
I've inserted pipes in my model however they are not showing up in Section Views. Please see attached screen-grabs.
I've checked the visibility options and everything appears to be turned on and they are not hidden. I've also checked the levels of the pipes & section.
IMG_01: Shows the family I've used for the pipes.
IMG_02: Shows the "Reveal Hidden Elements" - pipes not seen.
IMG_03: Shows the pipes modelled in 3d view.
Any help appreciated. Thanks
MostafaElashmawy
go to the section, and make sure that the discipline is coordination or plumbing.
Mostafa Elashmawy
RDAOU
@Joe_Hughes
Change the view' "Detail Level" to Medium of Fine...you are using coarse ie: pipes don't show
