For council submitals I need to show drainage flow lines on all my floor plans and site plan.
These drawings also contain various other information and need to be displayed in "hidden line" visual style.
How can i show my drainage reticualtion (which is under the ground) as, preferably, a single arrowed lines showing flow in a smart parametric way that isnt tracing over the pipes with drafting lines?
Thanks!
... try setting discipline to plumbing and detail level to medium.
edit: you could use view filters and color to differentiate and show sizes ie. ? Hope that helps.
edit2: I don't know the best/a parametric way to show flow direction really, from what I've found there's this workaround using pipe tags... But if you'd use a gradiënt of color with before mentioned view filters ie. you might be able to use that graphically.
1-Set view Wireframe
2-Go to view>Show Hiddel lines, Slelect first the topography then the pipe.
3-Set the pipes as Coarse (VG)
I dont get it. The view cant be in wireframe. It will not be readable as a council submission drawing.
Interesting, seems to work in my model though... Another idea might be to overlay those two on your sheet...
edit: you could use hidden lines setting (from view properties that is), but it will also show construction elements below your floor etc... ofcourse you could make another view filter for those (to filter structural elements by level at or below your plan view level ie.).
I was sort of doing something similar at the moment, below view filters gave me a nice enough result. for my purposes. Hope this works for you aswell, there's probably a better method out there though...
In combination with view set to hidden line, discipline architectural, show hidden lines all.
@Seychellian wrote:For council submitals I need to show drainage flow lines on all my floor plans and site plan.
What does piping have to do with drainage flow lines??? Nothing. Drainage flow lines are simply arrows indicating the direction of surface runoff. Generally, there is math involved and swales to design.
@barthbradley "...drainage reticualtion [...] [method] that isnt tracing over the pipes [...]" Anyway, I don't have a better answer for you @Seychellian at this time, but perhaps bradley has something up his sleeves... often does anyway^^
@barthbradley ow, I took from OP's question he needs to show piping below groundlevel on his plans with flow direction in a better way instead of drawing on top of those using detail lines ie. So drainage flow lines might be something else strictly speaking as you put it, but I don't think that was the question. Could be mistaken though.
- Create a different plan view, set the discipline to Plumbing, Coarse , Show the underground Piping only.
- VG and set Pipes line to Hidden
- Place Spot Slopes
- Place the View on the same Sheet as your main view
Sh*t rolls down hill -- away from the home -- regardless of the direction the drainage slope arrows are pointing on the Plot Plan. 😉
Gravity rules.
Seems like someone forgot to take his Tourettes Syndrome tablets this morning? 😆 Everyone else seems to get what im saying so im going to go ahead and presume that its you and not me.
@ToanDN wrote:- Create a different plan view, set the discipline to Plumbing, Coarse , Show the underground Piping only.
- Place Spot Slopes
They want to see the sewage and drainage information overlaid onto the master layouts like in the attached drawing.
Don't think it's Tourette's. Maybe early onset dementia? Dunno.
You're not by any chance doing a Septic System?
To use command Show Hidden lines you need to "See" the pipe.
Then ofc turn back hidden line visual graphic
@Seychellian wrote:
@ToanDN wrote:Show the underground Piping only. [..] - Place the View on the same Sheet as your main view
I think the idea was to place the two views on top of each other on sheet. Using spot slopes is a good way to show direction ofcourse, shouldn't be that many to place. Another idea could be to export the above view to .dwg and re-insert/link it onto the original view, but then ofcourse it doesn't reflect changes automatically anymore.
@barthbradley wrote:Don't think it's Tourette's. Maybe early onset dementia? Dunno.
Im not pyschatirst but im seeing a lot of Tourettes with a smidgen of hystrionic PD.
I am doing a planning submission where they want to see the schematic sewage and waste water disposal from the building (i.e sewage to septic tank and drainage to soakaways).
As it is schematic I am reluctant to try to model a complex drainage system with falls etc just in order to be able to tag it and show the flow direction.
Is there an arrow line pattern that I can use to do it with linework? I have seen arrow line based detail family which is not so attractive to me as it is difficult/impossible to do curved routes (as showsn below)
@Seychellian tbh not sure what you're doing anymore, but starting to think it's easier to just draw it as detail lines/line-based annotations (with 45 degree angles etc.). 😅
