Phasing: Window demotion and replacement with smaller one
autoMick
Advisor Advisor
autoMick
Hi, I drawing up phases in a rennovation. I have two phases
  • Existing
  • New Construction (during which demoition also occurs)
and have 3 plan views showing:
  • Existing Phase (Show All)
  • Existing + Demolition (Show Previous + Demo)
  • Existing + Demolition + New Construction (Show All)
My issue is with a 3 panel window (including sliding glass door) which is to be demolished and replaced by a 2 panel window (including glass door). The remaining bay is to be bricked up. What is happening is that the demolition of the 3 bay window during the new construction phase is closing up the opening as it should, however the addition of the new 2 bay window is not creating its new opening correctly (I think). The result being that new window remains bricked up. I'm not sure if this is a display issue or a family issue.
I hope this is making some sense. Attached are screen shots of the 3 plan views described above
- Mick
3D Existing.PNGExisting
 3D New.PNGNew Construction
 Exist.PNGExisting
 Demo.PNGDemolition
Civil3d user in Australia since 2012.
LisaDrago
So you have probably already checked this - but is everything on the correct phase - the phase created for the wall is existing, the  phase created for the 3 panel window is existing, then it is demo'ed in new construction, and then the new window phase created is new construction. Right?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
autoMick
Hi Lisa, yes I've checked all is correct. I think what is happening is that there are four things happening during the new construction phase, and revit is not getting them in the right order. What should happen is:
- old window is demolished
- old opening is closed
- new window is created
- new opening created
but what I think is happening is:
I've read elsewhere that there is no need to create a separate phase just for 'demolition' but maybe this is a case where it is required?
autoMick
Actually, I've just fixed it. I moved the new window to a new unaffected part of the wall, then moved it back to to the correct location - and now it works as desired. Thanks for the input.
Regards
- Mick
