Phasing vs pattern
Phasing vs pattern
Message 1 of 22
Phasing vs pattern
Is there a way to show my existing wall with 2 patterns?
Example: I have a blocks wall and I want to show the block pattern and I also want to show that it is existing, so I wanna have a gray shade behind.
Is there any way?
I tried changing the phasing parameters and set some filters...didn't work.
Replies (21)
Message 21 of 22
I tried both and the only one that worked was when I "wireframed" the main view...
Message 22 of 22
You must place the main view (Hidden) on sheet first, then the pattern view (Wireframe).
