Phasing vs pattern
Phasing vs pattern
Message 1 of 22
Phasing vs pattern
Is there a way to show my existing wall with 2 patterns?
Example: I have a blocks wall and I want to show the block pattern and I also want to show that it is existing, so I wanna have a gray shade behind.
Is there any way?
I tried changing the phasing parameters and set some filters...didn't work.
Replies (21)
Message 2 of 22
Revit 2019 (or 2018) and newer introduced 2 pattern (foreground and background) for any elements. You can create existing wall types and make use of them (phase filter must be 'show complete').
If you want to use Show Previous + New phase filter, then you need to overlay two views on sheet, to show two different patterns.
Message 3 of 22
Yea...neither of these solution would work here...
But in this post: https://forums.autodesk.com/t5/revit-architecture-forum/phasing-graphics-and-detail-level/m-p/595844...
They seem to be talking about a phasing/filter solution...but I can't make it work... 😕
Message 4 of 22
What version of Revit are you using?
Message 5 of 22
Message 6 of 22
I don't understand why @ToanDN 's suggestion doesn't work then.  The way I understand it, is that you want the Cut Pattern to look different for Existing.  You should be able to do with Phase Filters and Graphic Overrides with no problem.
Oops. My bad.  2018 does not have that ability.
Message 7 of 22
You are on 2018 so the 1st one will not work by nature.  The 2nd one should work regardless of versions.
Message 8 of 22
Probably, but that would take a lot of time and we can't afford that...
But thank you 🙂
Message 9 of 22
Why not duplicate the Material and give one a different shading to use for Existing types?
Message 10 of 22
Message 11 of 22
But thank you 🙂
Yes you will have to duplicate the views but you can get it done more quickly than you think with a View Template and Scope Boxes.
- a scope box to match the view crop of the two views
- a view template to control the graphics of all the secondary views at once
Message 12 of 22
Because my plans are in hidden lines...that won't work 😕
Message 13 of 22
Just tried it...don't understand how you get a transparent gray...
Message 14 of 22
Pattycake_Kyle
Possible dumb work-around... you could layer different patterns on top of each other to achieve something similar. It kinda sucks though cause its deviating from industry standard and causing yourself a whole bunch of headaches with representing materials. So actually forget this idea, but still posting it anyway.
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Message 15 of 22
Hidden, but shaded???
How about this workaround:  No shading, different cut patterns and a Wall Legend.  Smiley Wink
Message 16 of 22
The  second view (the one showing wall patterns, not phasing pattern) is Wireframe.  I have attached the revit file in that post.
Message 17 of 22
Oh...
Well I don't want my plans to be Wireframe...it's not looking good at all 😕
But I guess I learned something, thank you 🙂
Message 18 of 22
Not what we are looking for here in this office, but thanks 😉
Message 19 of 22
Haha thanks anyway 😛
Message 20 of 22
@Anonymous wrote:
Oh...
You main view still Hidden.  Only the overlaying view with only walls category turned on to show the patterns is Wireframe.
Example of a working project.
