Phases and View Template filters
hliS658H
hliS658H
I have a sheet with two views, one is phase A, one is phase B, they use the same view template. In the view template I set filters for color and line shade tone. But these filters only work on Phase A but not B - so in the view of Phase A, the skylights become blue and the PV panels show half tone. However, the view of Phase B, I don't see the change. Therefore the overall sheet doesn't look right. What are the possible reasons? Any input will be appreciated.
Set the views phase filter to show complete.
hliS658H
It is currently set show complete.
hliS658H
Sorry, I just double checked. The view templates are different, but the same filters are added into both templates, they work with one template but not the other. What could stop the filters from working?
cem_acikada
same problem here.
same view templates,
one does show the object which are created in new construction phase,
one doesnt.
cem_acikada
I think phase filter is way more complicated than it sounds.
I am creating filters for phases in the view template to make it usefull.
kadmonkee
filters are view specific change the rules for the filter in each view independent of each other
A = red
B= Blue etc.
or create a different filter
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
