Perspective mode simply doesn't work - help appreciated (look at the video)
jsanders
Message 1 of 50
jsanders
When I click on perspective mode, all hell breaks lose and the angle is extremely wide. Furthermore, the middle mouse button stops working and I can't orbit around my model. To orbit I have to manually grab the navigation bar and click on "orbit" button. I'm sure that this is not how Autodesk intended perspective mode to be used.
Why can't Autodesk implement a simple persepctive mode like Navisworks or even other software like Sketchup ?
Thanks for your help.
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
Replies (49)
Message 2 of 50
cbcarch
Try adjusting focal length in View Cube flyout menu.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 50
jsanders
Where is the View Cube flyout menu ? Also why can't I orbit with middle mouse button when in perspective ?
Message 4 of 50
cbcarch
Not actually in the View Cube--
http://therevitkid.blogspot.com/2015/03/revit-tip-increase-decrease-focal.html
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/screencast/Main/Details/a...
Cliff B. Collins
Message 5 of 50
RobDraw
I think questions like this detract from the actual issue. Is this what you want to know (It's the only question you asked.) or would you like people to focus on finding a solution for your problems?
Rob
Message 6 of 50
I think your Revit is broken. I tried like heck to replicate what you are showing. I cannot.  Do you experience this behavior in all projects? Have you applied the latest update?  Could this be hardware related?
@cbcarch , @RobDraw : Can you guys replicate?
Message 7 of 50
No issues here.  Perspective looks fine and panning/orbiting works normally with the middle mouse button.
https://knowledge.autodesk.com/community/screencast/cc32d38e-3097-430a-9acd-54b721ea24b1
Screencast will be displayed here after you click Post.
Message 8 of 50
loboarch
It looks like somehow the center of rotation and the camera itself are really close and zoom is locked or something? When you use the Steering Wheel tool, can you change the orbit center point? and maybe zoom out with the steering wheel?
Is this something that happens in only one file or files started from the same template? maybe something there messing it up, some kind of hidden geometry way away from where you are modeling maybe?
As for "Why can't Autodesk implement a simple persepctive mode like Navisworks .... ?"
3d Navigation controls across Autodesk products share a common toolset/code base. So Navisworks and Revit 3d Navigation should be/are very similar.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 9 of 50
RobDraw
You seem to have a lot of trouble with perspective views that other people cannot replicate. Why do you blame Autodesk?
Rob
Message 10 of 50
jsanders
I downloaded and installed Revit 2019.2 and then tried. It still doesn't work. I'm happy to know that it works for other people.
So the question to be asked is : Why is perspective mode not working on my Revit version ?
I asked a colleague who has also installed Revit 2019 and he has the exact same problem, the exact same bug. I don't think it's a coincidence.
Here is a screencast where I open Revit and toggle perspective mode. There are no added parameters.
(link https://knowledge.autodesk.com/community/screencast/23c13685-3f48-47d1-86e3-82de9cdf5bc9)
Message 11 of 50
cbcarch
Did you try adjusting the focal length as I suggested above?
Cliff B. Collins
Message 12 of 50
jsanders
Yes I can do that but it doesn't really fix the problem. It still acts very weird and when I move the model after some time I have to modify the focal length again because it just bugs out.
What I don't understand is why Revit doesn't automatically adjust the focal lenght like Navisworks does for example.
Message 13 of 50
cbcarch
Try setting up a Camera View--from a Plan View, instead of changing an axonometric/parallel view to a perspective view.
Do you still have the odd display behavior?
Cliff B. Collins
Message 14 of 50
jsanders
If I do this, then I take out the border of the camera and also change the focal length it seems to work fine.
Why doesn't the default 3D view have the same behaviour ? It's very very weird.
We are going to try and contact Autodesk directly since you can do it for example but not us which is not normal. The default 3D should have a comfortable perspective viewing experience, just like on your computer.
Message 15 of 50
Can you share that test file?
Message 16 of 50
Message 17 of 50
jsanders
Revit is not slow, it seems you don't understand the problem. The problem is that when I click on perspective mode, the view is not "user-friendly", focal length seems to always be incredibly high, and when I try to orbit around the model it doesn't work as intended.
Maybe we this is happening only on the french / EU version of Revit and not the USA one.
Message 18 of 50
When you 3D Orbit in a Perspective or Orthographic view the center of rotation is always going to be different.
If you want more control over how you rotate select an object and Revit will rotate with that object being the center axis.
It has been like that as long as I have been using Revit....
Message 19 of 50
 "Revit is not slow, it seems you don't understand the problem".  That's your response, @jsanders???
Did you bother reading the thread that @Anonymous linked you to? The information in it could very well pertain to your issue. In fact, the title of the thread could easily be changed from "Revit 2019 is slow in perspective view when panning" to "Perspective mode simply doesn't work"  (the title of this thread).
Do you do much troubleshooting? In my experience, most times the solution is found in the oddest place -- or a series odd places, if you know what I mean.
 bonne journée
Message 20 of 50
S'il vous plaît, can you tell us the Graphics Card you are using?
Merci
