PENDANT LIGHT FIXTURES HANGING WRONGLY FROM THE CEILING
ngurearchitect
Message 1 of 21
ngurearchitect
I am a revit novice and I have been trying for days to figure out whats the problem with this fixture.
Whenever I place M pendant light - hemisphere and disk on my ceiling, they do not hang from the ceiling like they should but instead attach to it with the rod sticking out above the ceiling. This problem seems specific to this two light fixtures as the rest work fine. I anyone has any ideas as to how to solve this please help.
I am currently using revit 2020 on windows 10,64 bit.
Replies (20)
Message 2 of 21
RobDraw
Good news. It's not you. The family is made wrong. It's got two horizontal reference planes.
I'm away from Revit so I can't show you what to do but there are a couple of threads about this. Do a search here or over in the MEP forum and you will find the solution.
Rob
Message 3 of 21
The OOTB Family has 2 "Origin" Ref. Planes. Pick the lower Ref. Plane in Elevation View and untick "Origin" in its properties.
Message 4 of 21
I'm in the same boat with OP and I'm not sure if I understand the steps you provided. Is it possible to elaborate? Currently learning Revit... Thanks in advanced!
Message 5 of 21
Picture help?
Message 6 of 21
or, are you talking about this:
Message 7 of 21
RobDraw
We could give you the exact steps to solve this issue or you could start learning the basics of family editing.
I'm going with the latter. This is family making 101. Get a tutorial under your belt and your solution will be forthcoming. This is a very valuable skill to have in your toolbox.
If you are in a pinch and need an immediate solution, open the family and try to find the two horizontal reference planes. Select the loser one and look at the properties for Defines Origin. Uncheck that box.
Rob
Message 8 of 21
I clicked Edit family for the light fixture and I do not see any reference planes. These are light fixtures from Revit and not any special lighting.
Message 9 of 21
Type VV and turn on the Ref. Plane Category under Annotations Tab.
Message 10 of 21
RobDraw
That's a different family from the one the OP was referring to. Is there a problem with that family, too?
Rob
Message 11 of 21
Message 12 of 21
The first screen shot is all that shows after turning on annotations. Still no reference line... I also posted an image of 3D model to show the issues just in case it changes things.
Message 13 of 21
RobDraw
@barthbradley wrote:
Huh? Reference Planes are in every Family.  But whatever; if you want to jump in here and lend a hand, then go for it.
When did I say there weren't any reference planes?
Rob
Message 14 of 21
@Anonymous:
The Top Screenshot is from your Family; right? Elevation View; right?  Type VV and the Visibility and Graphics Dialog will open up, Go to the Annotation Tab and check the box next to Reference Planes to turn them on in the View.  If they don't turn on, then they must be Temporarily Hidden in the View. Go to the dropdown under the Eyeglass icon and see.  No pun intended.
Message 15 of 21
I'm not sure what you were pointing out, or which one of my posts you were responding to. I'm talking about Ref. Planes though. I thought you were too.  Whatever. If my comment to you was inappropriate sounding, I apologize.  You are one of my favorites around here.  We good?
Message 16 of 21
I realized that it was in 3D plane on front so it looked like an elevation. I had to click on an element of the light fixture and click Edit Work Plan to get to the elevation. It worked though by following your first instruction! Thanks for your patience and help! Very much appreciated!
Message 17 of 21
RobDraw
I quoted the post that I was responding to. The one where you told me that there are reference planes in every family. I never said that they weren't in every family and not sure why you felt the need to tell me.
Rob
Message 18 of 21
You're right. It was a stupid thing to say -- especially to you. I was able to delete the post.
Message 19 of 21
Just for the record, @RobDraw -- you did not quote another post in the post I responded to, which was Message #11.
I didn't even see your Message #7 until just now.
...puts my post to you in a completley different context now -- doesn't it?  😉
Message 20 of 21
You are looking at a 3D view.  Open an elevation then you will see ref planes.
