PDF printing lines look jittery
manikandan_hochtiefindia_in
Observer Observer
Observer
Observer
When I look at the elements in Revit Sheet, they look fine. But when exported to A3 Vector PDF, the lines that are not straight, like Circle, Arc, diagonal lines look jittery. How to fix this?
Observer
Observer
This does not solve my issue. My sheet is of an assembly view and shadows are turned off by default. Still this issue arises. Perhaps it is the fine circles and smaller details printed on a smaller paper like A3. Even detail lines / detail items are affected by this.
cliffordshorey
Community Visitor
Community Visitor
Have you been able to solve this issue?
RSomppi
Have you checked the resolution setting in your PDF settings?
SteveKStafford
Apart from the article shared earlier... make sure there are no DWG files visible in the view(s) you're print. A DWG with extents that are too large for Revit's liking will also cause "jittery" linework. It's usually visible in Revit views too, not just after printing...but double check.
Steve Stafford
syman2000
Which PDF driver are you using? - Adobe, CutePDF, Bluebeam or Revit to PDF? Also do you have object with thousands of lines embedded into the family? Please share the file so we can take a closer look.
