PDF export using sheet number parameter
Rudolf_Wilhco
Message 1 of 10
Rudolf_Wilhco
In previous versions of Revit I could set up our file name convention of project name_sheet number_sheet name(Revision)(sheet size). In the current 2025.2 the sheet number parameter doesn't work for pdf export. The sheet number parameter works everywhere else, ie drawing list, tags and browser organizer.
Am I missing something?
Replies (9)
Message 2 of 10
jay_colcombe
Hi I have just repeated as a test and cannot replicate it unfortunately - is the sheet Number Reference in your sheets the generic OOTB Labe/Parameter?
Also are you using the Sheet Number from the View?
As you can see here it pulls the Sheet Number from the Sheet but not the one from the View
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 10
Rudolf_Wilhco
Hi. Yes Im using the OOTB parameter/label in the sheet. I have also deleted the old and replaced again. This very same sheet and project file worked perfectly fine in Revit 2024.
I have also tried this in other projects on Revit 2025 with the same result. All of which worked in 2024.
Using the sheet number as filter in other areas such as organizing and sheet list, works perfectly fine as well
Screenshot 2024-09-02 074708.jpgScreenshot 2024-09-02 074730.jpgScreenshot 2024-09-02 074852.jpg
Message 4 of 10
Rudolf_Wilhco
I see my mistake. I was using the 'Sheet Number' from the 'View' drop down and not the ' Sheet' drop down
Message 5 of 10
jay_colcombe
That’s why I mentioned it in my initial reply - it has caught a few people out!
Glad we got solved the issue!
Jay Colcombe
Message 6 of 10
handjonathan
Great work @Rudolf_Wilhco & @jay_colcombe
I'm glad you got this all sorted. It caught me out in the past 🙂
Jonathan Hand
Technical Marketing Manager | Construction
Message 7 of 10
carracsu
can i ask how the sheet size was added to the parameter list please? TIA
Message 8 of 10
jay_colcombe
I think this is a User Defined Shared Parameter
Jay Colcombe
Message 9 of 10
carracsu
Thanks do you think it is shared parameter set up as part of the original titlesheet? Its valuable information in the pdf title for printing
Message 10 of 10
jay_colcombe
Yes probably company specific!
Revit Sheet List Schedule By Page Size - Micrographics
Jay Colcombe
