How to manage The visual Style
nguyen-thuy-ai-trang
Message 1 of 12
I don't know somehow which command that I used making this model like this? Please let me know how to reset it.
Replies (11)
Message 2 of 12
Message 3 of 12
Well, my file is Structure so I didnt draw any Rebar. anw, thank you for your support.
Message 4 of 12
What is your screenshot showing that you want to show. I thought it was rebar. Guess not.
Message 5 of 12
I just want to make view ② could be smoothed like the view ①. That's what I meant. 😞
Message 6 of 12
blank...
Those are pipes, right?
Switch discipline to plumbing.
Message 7 of 12
I just want to make view ① could be smoothed like the view②. That's what I meant.
Message 8 of 12
I just want to make the view ① could be smoothed like the view ②. That's what I meant.
Message 9 of 12
I just want to make the view ① could be smoothed like the view ②. That's what I meant.スクリーンショット 2024-08-30 125417.png
Message 10 of 12
Honestly then, the View looks corrupted. It happens sometimes. Did you try recreating the View? Also, are you aware that Ambient Shadows are turned on? If the "issue" is persistent, maybe your Graphic Card is the culprit.  Turn Hardware Acceleration off.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Changing-the-Hardw...
...one more for you:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Elements-appear-in...
Message 11 of 12
What exactly are you marking as The Accepted Solution here, @nguyen-thuy-ai-trang?
Message 12 of 12
I couldnt reply my answer so I tried to find so many ways to post. But Autodesk marked my reply as a spam. 😶
Thanks for your reply.
