Hi, I've been working on a project and I've imported a SAT file into an in-place component a couple weeks ago. Now I've been trying to import another SAT file I've exported from Rhino and it doesn't get imported (when I go close the component editor it says that that the family is empty).
I've tried imported the same SAT file I imported before and it also doesn't work. I'm working with revit 2025, I tried with Revit 2024 and also doesn't work.
I even tried making a family and importing there the file and nothing. Please help!
I'm attaching the SAT file.
I didn't notice that SAT it not a supported format for the forum. I exported the rhino as dwg, don't know if it could work to figure out what is wront
I was able to insert the DWG onto a family, but then when I load it into the project it doesn't show up at all. Also the SAT files don't even show when I try to insert them into a family.
Actually, post your RVT (containing the RFA/DWG) here so I can troubleshoot it.
