V/G Icons wont work anywhere with or without a template not matter if I use a shortcut or if I click any icon
this is a problem with all of my revit version 2023-2025.
Does your firm use Guardian?
Steve Stafford
No we don't have anything that should interfere. The only recent change I can consider is downloading TeamViewer but I've been using it together with Revit for over a decade.
Also FYI I have 3 hard drives installed and Revit is installed on the 2nd slot
@yeshaya23 wrote:V/G Icons wont work anywhere with or without a template not matter if I use a shortcut or if I click any icon
It happens everywhere??? I thinking hardware then. Maybe Graphics Card.
Yes everywhere. I tried uninstalling 2024 and reinstalling, same problem. I tried installing 2025, same issue. Im thinking now I should check my Nvidia settings.
btw I have i9-13900k+4090 rtx
Still no progress. I am now uninstalling everything autodesk from my pc and try installing from scratch
Let's confirm. You have NO access to View Visibility and Graphic Overrides in any Project. Right?
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-154ADD7C-2ED2-4BA0-8D24-77F63AA4329D
Right, I also can't manage links or open the options tab from the R icon in the top left.
Processor 13th Gen Intel(R) Core(TM) i9-13900K 3.00 GHz
Installed RAM 64.0 GB (63.8 GB usable)
Corsair Vengeance DDR5 RAM 64 GB (2x32GB) (CMK64GX5M2B5200C40)
Display Adapter NVIDIA GeForce RTX 4090 GPU
System type 64-bit operating system, x64-based processor
Edition Windows 11 Pro
Version 23H2
Installed on 6/7/2024
OS build 22631.3880
@yeshaya23 wrote:I don't have anything like that on my desktop. Just adblocker in chrome
I would double check that. Maybe open in safe mode to be sure. With multiple dialog boxes not opening, I'm leaning towards something blocking ceratin windows from opening.
Could be a Win 11 compatibility issue. Open a support ticket on this through your autodesk.manage.com portal. Let us know what they say.
I booted to safe mode but the identity manager didn't work to start Revit. What else should I check in safe mode
Shouldn't interfere remains to be determined, no?
What add-ins for Revit are installed on your PC? If you have any at all, try removing them from the add-in folder temporarily and run Revit afterward so it can't find/run them.
Usually here: C:\ProgramData\Autodesk\Revit\Addins\
Sometimes here: C:\%YourUSERNAME%\AppData\Roaming\Autodesk\Revit\Addins\ or C:\%USERNAME%
Steve Stafford
I currently have no addins enabled. But my device manager I found I can't open properties tab from anything so it must be a windows 11 issue. I'm currently backing everything up and will revert back to windows 10
Aah, well that at least helps you know it's not isolated to Revit. Good luck! Before you bail out on 11, see if there are any new application barriers or options/settings it might have that can block users from certain tasks.
Steve Stafford
I've been trying to check for those types of things but with no luck. I tried disabling thr firewall but no diffence.
Where else can I look?
