PDF Export printing solid lines as dotted
liamN2SEF
liamN2SEF
I have run into a unique issue where I get different results from using the Print PDF vs Export PDF.
What is happening is when I export a pdf using the Export PDF button in Revit, the pdf looks fine when viewed digitally through a PDF viewer (I use Bluebeam Revu) but as soon as I print a physical copy the lines appear dashed/dotted. I do not experience this issue when I use the print function and print as a PDF. I'm attaching some images to illustrate. Does anyone know why this is doing this? Is there a setting that I’m missing?
Thanks in advance for the help.
jvpantin2
The behavior of PDF changes depending on vector/raster processing, you can select these options on both procedures bute they are located in different places: main window when exporting / Settings-Setup button when printing.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
ennujozlagam
Create new Line Style with the same specification
Use Raster Processing
Simon_Weel
What do you see when you zoom in on the PDF? Do you still see a continuous line?
Could you post the sample PDF?
liamN2SEF
@Simon_Weel They look the same when zooming in on the different PDFs in a pdf viewer like Bluebeam. It's not until the PDF is physically printed that the differences show. The original images that I attached were physically printed and then scanned back in so I could attach them to the thread. Here are screenshots of the 2 pdfs zoomed in before printing to paper:
Also in regard to previous comments/questions @jvpantin2. Both have been set up to have identical settings when generating the PDF whether it is from the PDF Export liamN2SEF_3-1688574241444.png
(ie. Vector vs Rastor, DPI, size, etc.).
