pattern thickness
pattern thickness
pattern thickness
Just a simple question, is it possible to choose different thickness for patterns in here?
THANKS A LOT
If it greyed out; no.
no no, it is where the cursor is. There is not thickness option i guess.
Are you saying nothing can be changed? If so, then that means the Visibility and Graphics Overrides are controlled via a View Template.  If you have no View Template assigned to the View, then you should be able to  override any category that is not grayed out.
Redrunner92
The line weight of Fill Patterns cannot be changed. They all use the same (thin) line weight.
Ah! Good thinking! Betcha that's what the OP is trying to change.
@Anonymous: That Hatch Pattern  Line Weight is controlled by your #1 Model Line Weight.  There is a Dynamo Routine out there that can change them if you really must.   Google it.
