I am an Civil Engineer, was work Two years with ATC Bangalore India, i have registered with Autodesk.com/partnerlearning and attend the assesment test also, using ATC user id and password.
Later i left the job and joint in some civil engineer firm.now i want to attend the test.
But i can't use ATC user ID and password. I created new user id and password also. when i am try to log it not accepting.
Is there any rules only ATC faculty should attend the test.
suggestion please.
Regards
wahid
suggestion please.
Regards
wahid
By reading your message, my opinion is that it is perfectly normal. If you don't work for that ATC anymore, the day you leave that place, the administrators need to end all your afiliations with the company, such as your account with that learning resource that you mentioned. You should not try to keep on using that resource if you don't work for that ATC any more.
