Part List from Revit Family File
Message 1 of 11
Revit and Inventor 2018, using both to design, document and fabricate our product.
Is it possible to create a list of each item/part in a Family File?
For example, a table Family File is created with legs, top, braces, etc. and flexed to different sizes using parameters.
Can I create a list of those parts with names, sizes, material, length in Revit?
J.
Replies (10)
Message 2 of 11
I'm not necessarily looking for the solution, but that would be great if available, but just if it's possible to do in Revit would be helpful too.
J.
Message 3 of 11
cbcarch
Look into using Assemblies in Revit, and perhaps Parts.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 4 of 11
First step would be to construct your families with shared nested components (i.e. legs, top, braces, etc., all as individual families).
Message 5 of 11
Thanks for the suggestions.
Message 6 of 11
cbcarch
For an itemized list with quantities
You can create a schedule of all the families as well, with Mark, size, model number, materials/finishes, Grand Totals, etc.
Cliff B. Collins
Message 7 of 11
Revit can additionally create an Assembly and Assembly Views for each one of these components at the press of a button.
Each component is a shared family with the host family shown in the lower right corner.
Message 8 of 11
Yes, doing that. Thank you.
Message 9 of 11
Thank you, so assuming your Item #1 is a parametric Family File. I'm looking for a list of each of those parts, the bottom plate, the top plate, each gusset plate from that Family broken out into a list. Can that be achieved?
J.
Message 10 of 11
That pretty much what I'm showing in the picture.  Any "value" within the family that is a Shared Parameter or System Parameter will be available to the schedule.  So, the short answer is "Yes; it's achievable".
Message 11 of 11
Thank you, I'll run with that.
J.
