Paremeter hexagonal geometry
Marielen_
Marielen_
I would like to paremeter lenght and width this geometry:
but I can't do it equidistantly between the center, can someone help?
GustavoUbriaco
Maybe this works, you have to make some esqual distances to fix the hexagon to the center, then place angular dimensions and block them only in 5 inside corners to don't get a circular error
Gustavo Ubriaco Contreras
GustavoUbriaco
Here you are a little example have an excellent day
syman2000
Here is alternative if you want to define the width of the edge while it auto calculate the length and height of the foundation footing.
