Hello
I have Skp file with me (i don't like to work in sketchup), how can i convert to Revit 2019/2021 Model like so,
I want that SketchUp faces and components to Revit walls, doors, windows, roofs, and curtain walls etc.
and also the families are fully schedulable and use your firm's Revit template and content.
I want to edit its components in revit only. any idea?
Gelöst! Gehe zur Lösung
Gelöst von ahmadfiroozi000. Gehe zur Lösung
https://www.bimdex.com/sketchup-to-revit-export.php
this is a plugin that can help you
if you don't want to buy it you can use trial and export
You can import the SKP file as a CAD, as the next article says:
Another option, is import the file in FormIt (FormIt can open SKP files) and then save the model with the AXM extension (native FormIt extension).
In Revit, you can import that AXM file directly
https://windows.help.formit.autodesk.com/building-the-farnsworth-house/part-i/revit-interop
You can export your Sketchup as IFC. First you have to add IFC classification
Then you highlight the object and define the IFC object
Export it out as IFC
In Revit, those object will categorized as Window.
That's great. So can i change its material or parameter also in Revit then? for render purpose
Yes once it is IFC import into Revit, it becomes Revit geometry and you can change material and add parameters
Another option is to open the SKP in FormIt, adjust/apply any materials, then import the FormIt model directly into Revit.
