Parametric Window Families
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I am fairly new to Revit but I do have a fairly good grasp on how to use and navigate the program. What I am trying to do is create a facade for the side of my building that is made up of parametric windows. I have created parametric constraints that surround an opening to what could be a window. These are made up of various extrusions that protrude from a basic window family. Currently, I have an opening of where a window should be and I would like to be able to insert a variable awning window that could also be constrained with parameters. The problem that I am having is that Revit does not recognize the solid protrusion from the wall as part of the wall thus I cannot insert a "window" into the opening that I have. I am wondering if I am going about this the right way or if there is an easier way to achieve the same result. Ultimately I want to be able to manipulate the "parametric window" that surrounds the opening, which I can already do, as well as manipulate the awning window within the opening of my window/wall facade. Is this something that is possible to do with parameters or is there a better way of going about this in general.
I am currently working within a window family.
Thanks for any help that anyone can offer!!
