Hello everyone, I've been working on creating this family, but I'm encountering an issue. When I load it into my project, the drag handles don't appear in 3D. However, when I load the same family into a new project, the drag handles show up just fine.
I've designed a right-angle triangle family with parameters for the angle, base, and height. Please refer to the screenshot below.
What am I missing here?
Solved by ralphdenhaan. Go to Solution.
Can you replace the reference planes with reference lines and try again?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
@ralphdenhaanIt's working now! Surprisingly, I tried the family with reference lines too. Maybe the drag handles were way outside the section box, but it's working now. Thanks!
