- Mute
- Permalink
- Report
Hey...I'm working on a parametric line-based array for a length of a conveyor to be used in a 2-click length format.
Everything flexes fine except for the height of the legs...the first one works before I insert the array, but once the array is made and the legs become 'grouped', the connection to the reference plane they were originally attached to fails and I have to remove the constraint. If I make it an array of 2 and go in and reconnect each to the RP it still gives an error.
I've even tried disconnecting the legs from the rest of the RP's and giving them their own height parameter to match that of the conveyor...it seems as though just the fact that they are in a array is breaking their ability to hold a height parameter
Any thoughts why this might be happening?
