Hello All,
I have a question about how to export every detail component from a project? I see the save as library will save every family in the project, but I specifically just want detail component families. Is there any quick way of doing this rather than having to save every single family and then weed out the ones that are not detail components? Any advice would be greatly appreciated before I just bite the bullet and do it the long way.
Thank you
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You can save a copy of the project, delete all model families via the browser, and Save As Library the remaining detail component families.
I suppose someone can even come up with a Dynamo Script to do it directly from the original project but I will leave it at that.
