I have a parametric array and I am trying to figure out the formula for the occasion where the array goes past a certain dimension, it would subtract one. My formula for the array is "Length/Spacing" where Length is 30' and spacing is 1'-4", which returns a Number of 23. This puts my last object outside of the 30'. I know that I can do "(Length/Spacing)-1", but that doesn't work in certain instances when the dimensions vary. I'm looking for a formula that would be along the lines of IF Spacing * Number is greater than Length, -1. <---- I know that isn't written right, I'm new to the more complex formula's.
Any resources for learning more about writing formulas would be great too, if anyone has such information.
Gelöst! Gehe zur Lösung
Gelöst von Ilic.Andrej. Gehe zur Lösung
You can also post what you've got and I'll modify it and return it to you.
I just came to post that I finally found a formula that works. I created a parameter that returned a value of length x spacing, which I called "count". I made another parameter that I called "Overage" that returned the value of "Spacing * Count". My final formula for my array was "if(Overage > Length, Count - 1, Count).
@barthbradley , sorry I didn't get to this sooner and save you some time in replying. All seems to be working in my family at the moment. Can you tell refer to a good resource for learning to write these formulas? I'm finding bits and pieces of info, probably enough for my purposes if I keep searching as I go. Thank you for your time!
Now that you got it figured out in that direction, how about the other direction? What if the Array count is less than 2? Have you figured that out yet?
What actually bothers you is the rounding of an array integer. For arrays, it is best to use a "rounddown" function. So, what is a rounddown? It rounds the number down. The round of 5.75 is 6, but the rounddown is 5.
So, the formula that you need is:
rounddown(Length/Spacing)
Try it.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
@barthbradley , Good point, it does break when I enter a length of less than 3'.
@ToanDN , I started to look at curtain walls as a solution but didn't get that far into it. The end result here is actually framed walls, where there will be headers, trimmers, backing, etc. The array was actually for the studs. Is such a thing possible in a curtain wall?
@Ilic.Andrej, I will try the ROUNDOWN function. Thank you for that bit of information!
You're welcome.
Andrej Ilić
MSc Arch
Vertical Curtain Mullions = Studs. Horizontal Curtain Mullions = Top/Bottom Tracks, Opening Headers/Sills.
Yes Curtain Wall is the best out-of-the-box tool for this.
@Ilic.Andrej, I just wanted to let you know that your solution worked perfectly. Thank you!
