Parameters Within Different Families
leandrorv_21
leandrorv_21
Hello.
I'm working with 3 different annotation families. Between the 3, I have one number that is common to all of them.
Basically, I calculated my Occupancy Load as a formula from 2 shared parameters (A2 Occ + A3 Occ)= Total OCC.
When I use that Total OCC Parameter in another family, is not retrieving the value of it. I tried to make it again as a formula of both A2 + A3 together but is not getting the same information. After that, I have to calculate the plumbing fixture counts and I need to split that Total OCC in 2 so I can get WC for men and women, and is not doing it automatically.
Any Ideas?
leandrorv_21_0-1695671303430.pngleandrorv_21_1-1695671326532.pngleandrorv_21_2-1695671338986.png
Alfredo_Medina
It sounds that you can benefit from using Global Parameters. You could create one or more global parameters to store values that you want several families to share.
leandrorv_21
Is this applicable to families? Like annotation Families?
Because I'm only finding shared parameters in families edition.
Alfredo_Medina
Any family. The idea is that you can associate parameters of the family, or families, to global parameters in the project, not in the family editor.
Use pyRevit > Match Properties > choose any parameters (shared or not) from the source family to bring their value to the target families.
