I don't know how to model garage floor slab slopes in a proper way (I'd like min.1,5% slope , bottom point of drainage is -354cm) ? . Revit gives very strange partitions. Violet color is just a sketch line of drainage and partitions.
Model a flat floor @ -354 mm. Edit sub-elements and raise the edge @ the highest point to an elevation that give you 1.5% slope min. (you can place a spot slope and see the value when you are adjusting the high edge), or do some quick math.
You can also model a slope floor instead of a flat floor, at -354 mm elevation, and give the lower boundary a slope of 1.5%.
Leave alone the original floor and add another floor on top for the slope. I would set the slope floor as variable
Next you sketch your slope, follow the outline and then edit the floor point to get your slope.
