Parameter lost after division
Is it possible to preserve element prameters after dividing it using „split”?
Im spliting wall and only one part is left with earlier delfined parameters
What parameters specifically?
My custom „project parameter” whitch is a string
if you can use a built-in parameter such as Comments then the value will remain after you split the wall.  But I have not found a way to do the same for user created parameters automatically.
