Formula with YES/NO with if
DanielLemen
Message 1 of 8
DanielLemen
I would like to know how I made my object. I've made 2 part "Graphics" "Visible" that i would like to trigger some how.
I would like to manage an IF statement like this
IF Tibi 600 then
Part 600
else
Part 400
ENDIF
HOW do I made that in Revit?
And then put into my .txt files Tibi 600##OTHER## 0,1,0,0,1 and sooo on.
Very simple questions but I really do not understand this in Revit.
Replies (7)
Message 2 of 8
Ilic.Andrej
if statement is like this:
if(condition,result if true,result if false)
In your case:
The parameter called Part is defined by formula   if(Tibi=600,600,400)
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 8
Ilic.Andrej
Andrej Ilić
MSc Arch
Message 4 of 8
DanielLemen
I've been reading if(condition,result if true,result if false) but have no clue how to use it. I'm not thinking right.
But I wonder could u made a simple object so I can see?
Message 5 of 8
Ilic.Andrej
Tell me what you want, do you want to control the visibility of an object or its length? What is your condition?
Andrej Ilić
MSc Arch
Message 6 of 8
Ilic.Andrej
For example, if you want to control the visibility of two objects, create three yes/no parameters (for example, one is called "a" ,the other one "b" and the third one "Tibi"). Select objects and look at their properties, next to the param called "visibility", there is a button. Click it and assign yes/no parameters that you created. First object is constrained with param called "a" and the second one with "b".
Now, open family parameters dialog. For param called "a", asign this formula
Tibi
For param called "b", assign this formula
not(Tibi)
So whenever user clicks "Tibi", he will turn one object on and the other one off.
I'm really guessing here what you want, you need to explain a bit more....
Andrej Ilić
MSc Arch
Message 7 of 8
DanielLemen
This is what I asked for. Thanks alot!
For me it's hard to understand it. not(Tibi) was the answer I needed. That's to easy 😛
Message 8 of 8
Ilic.Andrej
You re welcome 🙂
Andrej Ilić
MSc Arch
